Sideview mirror fix?
Well... somehow my pax sideview mirror is free-moving. It will move 90 degress in either direction (until it hits the car). I can lift it up, and off if not for the wires inside. It appears broken. Any way to fix it, short of superglue?
Super Moderator
Not glue This can be fixed, It is however a pain in the butt !
You need to remove the entire mirror and base.
You will see there is a big spring you must compress and than with a large screwdriver tighten the nut.
When you take it apart you will see what I mean, any questions let me know I have done this several times.
Once the two mirror sections seperate the whole mirror has to be taken off the door to get to the special bolt and apply the pressure to get it to engauge the threads in the housing.
You have to use a speical metric tool to push the pins out of the white nylon connector next to the mirror transmission. Also the same 12 point bit that is used for the flywheel bolts is the same size as the splines in the special hollow bolt.
This is a Matco number WT565 that was reported to work. Has to be the metric tool and not the inch tool.
Also Lisle #56500
http://www.lislecorp.com/tools/cata...ical/elect1.htm
and AMP part # 305183
Here is a write up using a home brew compression device:
www.951motorsports.com
Also gives some extended pointers.
Also Lisle #56500
I had the same issue; it is a pain in the ***. Concede the fact that you will need to remove the entire mirror. The internal spring requires a good deal of effort.
Frankly, if you've considered the 968 mirror upgrade, NOW IS THE TIME. In hindsight, I would have done the upgrade at that time, since the PITA factor is equally high for repair or replacement...Good luck!
Wow.. I am really building up to PITA repair list.
Sunroof gears, radiator, front cam seal, and now this. Yee-haw.
Thank you very much for the info. I have never considered the 968 upgrade.. but I will now!
Well, if you're ever in Texas I can do the job in about 30 minutes. And that includes clean up.
This is one of those jobs where it takes FOREVER the first time, an hour or so the second, and then you're pretty much an expert and can do it in a few minutes. Steep learning curve if you know what I mean.
Super Moderator
Originally posted by Marc Gelefsky
Keith is correct, I can do the mirror job in about a half hour, with no special tools.
Or are you cutting and splicing the wires?
Super Moderator
Originally posted by SoCal Driver
How do you get the pins out of the connector?
But to compress the spiring I just used a big screwdriver.
The lazy way:
Once, I had someone around to help me and I was able to do it with the wires still attached, this however can be dangerous. If the person holding the mirror while you compress the springs slips, your going to have a nice dent in your door
