i bought a lemon
#31
no the oil looks fine. i just have the froth in the coolant tank. BUT, it does smoke a little on takeoff. i drive it hard. and im the forth owner, i dont know how they drove. i know the guy i bought it from lies. ok, i assumed it was the miles on my car because of oil slipping passed the rings and smoking now and then. but is it typical for the block to crack? im assuming the head gasket is original, but like i said the oil looks fine. should i look into a replacement engine instead? or fix the oil cooler leaks? the car has been overheated before, when my fan cut into my radiator hose. it wasnt running for long like that.
#34
Originally posted by emilysgranny
If your idle jumps around when the engine is cold then it is the aux air valve , if the engine does this when it is warmed up it is the tpi .As to your ps leak, just pull the rubber boot back off the end of the ps rack and see if has oil in it. That is a bad rack seal.Other places that are prone to trouble are the little hose under the ps reserviour being loose , and bad seals in the ps pump itself. I think Travis has repair kits for all these leaks.
