Question about replacement fuel line compression fittings
I just installed a replacement high pressure fuel line on our 944, similar to the lindsey racing kit. Its the type where you cut the old hard line and use a compression bite fitting to transition between the old hard line and the new flexible line.
Anyway, I fixed the thing in place and tightened it down, tested it, and it leaked fuel everywhere. I tightened it down some more to the point where I started worrying I had cross threaded the fitting, because it was getting far tighter than I was comfortable with. Tested and it still leaked a bit.
Last try - I had a friend hold one of the wrenches from the top (this is on an early car with the lines under the brake booster) and I turned the other side from the bottom. We put everything we had into it (a point where I usually start hearing things snap) and got it to the point where it just wouldn't move anymore.
It seems to be holding now - no leaks. I'm concerned that I didn't install the lines properly and that they may leak in the future. Are they supposed to take a massive amount of torque to work the compression fitting? I am not exaggerating when I say the amount of torque I put into this thing is usually enough to break whatever bolt I am turning. Calibrated wrist felt something like 70-90 ft lbs, about what I'd use on a wheel lug.
Thanks for the confirmation, that helps put me at ease a bit. In my garage, I am the gorilla which gets me into trouble as often as it helps.
The car is still on stands so its difficult to really test, but I just went out and ran the fuel pump for a good 10 seconds or so and again no leaks. I think its good.
