oil warning light on, pressure max'ed at 5
Old 02-28-2016 | 05:53 PM
audi49's Avatar
audi49
Default oil warning light on, pressure max'ed at 5
Today, for the first time, my oil warning light is on and the oil pressure is pegged at 5 immediately after i turn on the engine.
Oil level is within range.
The oil pressure gauge does not move unless i actually turn on the engine.
It happened just after i washed the car and so I'm suspicious it's an electrical issue.
Any thoughts what this would be and should i be concerned driving the car in this condition?
Thanks.
Old 02-28-2016 | 06:09 PM
Tiger03447's Avatar
Tiger03447
Read Triple 7's posts on his oil pressure gauge problems..might get a clue there. Let it dry out for a day or two and see if it goes away. Probably a bad or wet sender that's grounding out due to water. Just spitballin' here..
Old 02-28-2016 | 07:59 PM
mytrplseven's Avatar
mytrplseven
777 here....When I checked the connections on my sender, they weren't real tight. With the wires off, I still had a full scale deflection of the gauge with the ignition on. When I grounded that line, the gauge went to zero pressure. I checked the connections on the sender itself and found a short between both pins as well as to the case of the sender. Since none of this makes any sense to me and aftermarket senders have a poor reliability history, I ordered a new one from VDO, a reliable mfr. At some point I just give up and purchase a new component as opposed to trying to figure some of this stuff out. The wiring diagrams make no sense and I have 12 years experience in electronics (but not German electronics). We'll see if I made the right decision when the new sensor comes in.
Old 02-28-2016 | 08:10 PM
audi49's Avatar
audi49
Upon further review (and waiting 2 hours), my light is off and the pressure is back to normal. I think Tiger03447 may have been right... some moisture somewhere shorted something, and now it dried out. Hopefully all set for now. Thanks.
Old 02-28-2016 | 08:22 PM
marc abrams's Avatar
marc abrams
The brake fluid level switch can cause the oil pressure warning light to come on accompanied by the parking brake light.
Old 02-28-2016 | 09:45 PM
mytrplseven
Based on this I'd recommend ensuring the wires on the sender are tight and then spraying them with WD-40.
Old 02-28-2016 | 09:49 PM
audi49's Avatar
audi49
Where is the sender located? Thanks.
Actually figured it out. Below the oil filter. Will ck connections and the rubber boots that are on them.
Old 02-29-2016 | 11:44 AM
mytrplseven
Just under the Oil Filter. Jack up the passenger side, turn the front wheel full right and you'll have easy access. Use Jackstands.
Old 03-04-2016 | 09:36 PM
mytrplseven
Default Oil sender replacment.
Well, I received a VDO oil pressure sender today and after a little aggravation, oil and very little room to use an adjustable crescent wrench I changed out the sender. Now I have the low oil pressure warning light that wasn't there before and good oil pressure indications. Check that off the list.
Old 03-06-2016 | 03:56 PM
Tiger03447's Avatar
Tiger03447
Good to hear triple7 !! Now everyone, wins..!!
Old 03-07-2016 | 09:07 PM
951Tom's Avatar
951Tom
Crows foot socket is the trick to easily replacing the oil pressure sender. Sorry mytrplseven not much help after the fact.
Old 03-08-2016 | 01:23 PM
ramius665's Avatar
ramius665
The P 9244 special tool for adjusting early 944 tensioners is actually the perfect tool for this job. Have had to use it a couple of times over the years and it's far and away the easiest method. Even better, the wrench is only about $15 from Porsche.
Old 03-08-2016 | 02:16 PM
mytrplseven
I wish I had thought of that. It took me 1/2 hour with a crescent wrench trying to get it tightened, one degree at a time.
Old 04-06-2016 | 03:11 PM
hipst944r's Avatar
hipst944r
Was that ultimately the fix? I have the same issue with mine right now with a oil pressure sensor on the dock today.
Quick Reply: oil warning light on, pressure max'ed at 5
