ICESHARK Cables!
Dan, the main ground strap fit perfectly into the 968 Cab! I keep forgetting that the battery compartment ground is into a soft brass fitting, so stripped yet another one! Fortunately, it's an easy fix to replace that tapping screw with a proper SS 1/4-28 x 1 bolt.
I remembered to TAPE OVER that clutch inspection hole this time too! Funny how nervous you get when you think about that inspection hole all the time as you're working on that ground strap!
Thanks!
Now to get more people ordering that Full Boat Lighting Kit from you so I can get another harness for the headlights!
Thanks!
Done With Sidepatch
