Anything I need to watch out for?
I am going to be pulling the engine in my car and I have heard that there may be some sensors or something that I need to be careful not to move or anything. Does anyone know anything about this or anything that I should look out for while pulling it?
The two senors on the bellhousing/flywheel. You only need to pull the sensors out and if you have a late car there should be a sleeve that goes into one of the holes also. That needs to come out too, but don't remove the bracket from the block. It ha a set depth on it and if you pull it you'll have to reset the depth. Good luck
Big thirst, Sore Thumbs
Napoleon
Napoleon
If your going to pull the motor. Do yourself a favor. Replace the heater core. Engine out of the car it will be a realitive breeze, engine in the car...
Well I just spent 4 hours trying to get the hoses on and couldn't do it.
