water under drivers feet
I've had a bunch of 944 cars for 9 years now, so I'm familar with leaks, but this mysterious puddle of water has me stumped. After it rains, I get alot of water in the drivers area under the floormat. Can anyone guess where it might be coming from?
You could sit in the car while somebody sprays the car with a hose. When you see the water come in, you've found your leak.
The obvious ones are check the seals on your roof, doors, and windows, vents, and plugs in the firewall.
Check the door seal. Water can fill up the transom area and slop over onto the drivers foot area. Comes in from the back top of the door frome when the seal is worn and the door is out of alignment.
The other place I've heard of is around the fuse/relay box if there has been a hole or slot cut in the side of it for alarm wires.
Might want to have a look at the fresh air fan unit.
That one needs to be removed for work on the heater core and / or wiper mechanism..
Needs to be re-sealed with installation. Just that might not have been done properly.
TakeCare
TakeCare
