FS: 87 951 minus drivetrain - or part out whats left
Just throwing this thread up to see if anyone has interest in the car as a whole (whats left) before I part everything out. It is a 131838mile 1987 turbo, non-sunroof car, with the 474 suspension option. Alpine white exterior (not the best respray) with brown interior. It had a light hit in the front on the driver's side before I bought it. I made up GT style lights to get rid of the pop-ups because the brackets were a bit misaligned from the hit. New brass ball joints and poly bushings in front suspension done with very few miles since. Will come with stainless fuel lines in engine bay still installed. No rust, underside looks good, only real issues are the front damage and the respray.
Whats already removed and gone: engine with harness and all associated parts, clutch, TT, tranny, wheels, front seats, GT light setup.
I bought it in fall of 2009 and drove it until fall of 2014, the parts removed will be going into the 1991 S2 I bought because its in nicer overall shape and that engine is getting tired...
As it sits right now most of the front of the car is off because of the engine pull and the front and rear suspensions are off. All can go back on to the car if someone is interested. The driver's window regulator would need replacing as well. There is still some little stuff I need to pull out of it; aftermarket gauges, boost controller, some vac lines, etc. but nothing huge.
If no one is interested in it as a racecar or engine swap car or something then I will be parting it out over the winter.
I would be looking to get $3700 for it with everything that is still with it, or hit me with an offer.
I am located in Jericho, Vermont, about 15 minutes east of Burlington.
I might be interested in the light cover setup, so I could eliminate the pop ups. Might also be interested in the AFR gauge if it is still around. Once you get down to the bare hull, call up Retro Automotive in Claremont, NH to see if they will play ball on the rest. Hope this helps some..
