T-Belt check
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
Just a reminder to check the t belt tension. I did mine today after much procrastinating and it was way loose since I installed it 2K miles ago. Took all of 2 hours with an oil change included.
HTH
Tim
HTH
Tim
Better loose than too tight. The expansion of the engine will snap a belt if it's too tight.
A really loose belt will slap against itself at the water pump pulley and shear off teeth. This is why the newer water pumps have that metal fence there.
