freaking turnsignal
thanks so much guys!!
i was looking at the wrong fuse spot and when my flashlight looked over i saw a fuse with the strip totally popped and that turned out to be what fixed it.
i checked in the owners manual and saw that the horn that i was also complaining about not working had no relay at all, so i put my (marked #21) extra relay that i got for $5 earlier that was for the flashers, and stuck it into the horn slot and now have a working horn as well. is there any problem to sticking this relay there?
i was so pumped i knocked out a nice bit of engine degreasing and top end wiping down. nothing like having no turn signal to make a car feel like its not in top shape.
feeling really good about my car right now... now, just gotta figure out a small oil leak.
Thanks for the update.
At times trying to solve a problem with these cars can be a daunting task. Then, once you understand how the circuit works, the solution can be very simple.
Why not add this update to the "what did you do to your 924/944/951 thread.
