Gas in Motor Oil - Part II
After changing to fresh motor oil and driving ~80 miles, the oil reeked of gas, again.
So far, I've replaced/serviced the following:
-New O2 sensor
-New Fuel Dampener
-New Fuel Pressure Regulator (stock 2.5 bar)
-Injectors cleaned/resealed by Marren Fuel Injection
-Ensured Fuel Quality Switch was at full counter clockwise
-Ensured injectors didn't leak by monitoring rail pressure for 30 mins after shutdown, pulling fuel rail after shutdown, and running fuel pump with return hose clamped and fuel rail pulled = all tested ok
-New spark plugs which are a little discolored after ~80 miles, but not sooty.
What do you guys think is the next thing to check? As Danno said, it seems the fuel is getting into the oil in a liquid form, which points to the injectors. Are the injectors opening for too long? Are they leaking while driving, but not when the motor is off?
Thanks in advance!
-New O2 sensor
-New Fuel Dampener
Thanks in advance!
leakdown test
Have or perform a leak down test on each cylendar. It is possible your leaking fule into the oil pan through the rings. A Leak down will tell you if the rings are your weak point. You have done everything else.
good luck.
TaboII
good luck.
TaboII
Thanks TaboII,
I am thinking about doing a compression test myself, and if needed, have someone do a leak-down test (I don't have an air compressor).
Only thing is, the engine oil was fine prior to me doing the belts, injectors, TPS, chips, FPR (3 bar), upping the boost, etc.
I heard from the e-mail list that my DME may be bad? Will a bad temperature sensor cause that much fuel to be dumped into the engine? Will bad rings cause smoke to exit the exhaust (I have none)?
One more thought! though not a pleasent one
You have done a lot of nice work to this motor. Not to be a sour puss here but you have checked most everything else that I can think of personally. One possibility is that after all this great engine upgrading and modification "You simply cracked a ring" That would explain the gas in the oil problem you’re talking about. The Leak down test will tell you conclusively if this is a problem or not.
Just my .002
TaboII
Just my .002
TaboII
Originally posted by Legoland951
Does your car pass smog? If the emissions are clean, its not your fuel system or excessive fuel from the injectors.
Emissions - HC CO NOx
Test Limits - 0.80 15.0 2.00
Test Results - 0.45 5.6 1.66
I still smell gas in the oil, so do the test results indicate anything?
Re: One more thought! though not a pleasent one
Reason being after driving 3K miles on my rebuilt engine I still dump a bit of blue / black smoke out the tail pipe under heavy acceleration. I believe I may have cracked a tiny bit off the side of a ring.
Or could it simply be attributed to the fact I didnt have the head rebuilt and it was suspected of bad seals anyhow?
Christian
