Rear brakes look funny
I finally had the tires replaced on my 84-944 the tread was good but the dry rot was bad. I hardly ever drive this car. When they had the wheels off I got a good look at the discs. The fronts looked normal the back ones looked like the rear brakes were hardly ever touching the discs. I assume that this is not normal. I don’t really drive this car aggressively but I do not drive slowly. And I have never felt like I didn’t have enough braking power.
I had the brake line that runs from the master cylinder repaired a few years ago, it developed a leak where it was in contact with a screw. This was at a specialty Porsche repair place. They said at the time that they couldn’t get a new line so they cut the line and put a replacement piece in there. Now I am wondering if there is a crimp in the line and it is restricting the flow of the brake fluid to the rear break calipers.
I don’t have access to a lift to work under the car and I understand that you need to get the car high enough to snake the line in there. The brake line seems to be available or easily fabricated. I have in the past done a lot of work on cars myself but I have lost interest in doing a lot of that anymore. I am not sure if I should trust this repair place again.
Anyone have any suggestions or comments.
Try bleeding the whole system. I remember one time my rears weren't grabbing well at all right after some work that involved disconnecting/reconnecting the lines and it was just air in the system that didn't come out the first time. A lot of people on here really like the Motive power bleeder.
Bleed the rear brakes and see if you're getting good flow out of the bleeders. Could be a problem with your rubber flex lines on the back being collapsed internally or maybe the piston on the rear caliper is seized from lack of use and moisture contamination.
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
I discovered the same thing with the rear calipers on my car. When I took them off I found the piston had rusted to the bore under the rubber dust cap. 30 minutes in a heated ultrasonic cleaner got rid of most of the rust and the piston came out fine.
No rust internally, so I cleaned it up the rusty areas with a wire brush on a dremmel and rebuilt both calipers. Rear discs are nice and shiny now and with rebuilt brakes all the way around the car stops very nicely. I also installed new flex lines from the hard lines to the calipers.
