Timing belt, fact or Internet folklore?
#50
#51
I was thinking of this thread this morning as I went for 15lbs of boost in my Volvo 2.4T.
I get 50,000+ miles out of the belts on that car. I am having the WP done today for what I believe is the first time at 126,000 miles. And that car gets flogged!
#55
Does it really say remove the pulley and rear cover to change the belts, I thought that was for the water pump ? I didn't when I did the belts and pulleys. I wonder how long ago the cambelt tensioning procedure was written, and if it took account of the extra tension applied when the head/block expand at working temp.
#56
#57
Will this tool work on the 944?
#59
OK, l didn't want to dredge this up but thinking about this. l think l may have a answer. First a few things that helped me come to this conclusion.
It's been said here the timing belt is a new technology in 83. My earliest recollection of a timing belt used was the 1966 Pontiac OHC 6 cylinder. It's been said here it's a big 4 cylinder engine is hard on belts. Chrysler's 2.5L with a Turbo makes 150HP. It's been said here it's the power pluses of a 4 cylinder engine. Fiat and VW both had 4 cylinder diesel engines. Most 4 cylinder engine's the timing belt also drive's the oil pump. The 944 is the only car that l know of that the oil pump is driven off the crankshaft.
So what's my conclusion, as Dr. House says, everybody lies. I bet you a lot of those belt failure's the belt was never change. I also believe a lot of diy's (and professional mechanics too) have no idea how tight a belt should be or know a good roller form bad one. Yes some may have bad luck, but I just can't see how the 944 timing belt arrangement being problematic.
