Arnworx belt tensioning tool calibration question
I've offered to help a local Rennlister with a timing belt change and offered to loan him my Arnworx tool kit. I've used the kit on two cars in the past and have had no major problems, but need a little assistance now.
During my last belt re-tension I used generous amounts of engine de-greaser that removed the calibration value written on the calibration bar. The gauge still retains its calibration marking so I know what value to set the tool to. The issue is I now have no way of knowing which orientation to place the calibration bar into the tool! flipping the bar over will yield a different value so I know one side is correct, while the other is not.
I need to determine which is the correct orientation and stamp/scribe the bar to indicate this. Has anyone else faced this issue or have any ideas how to determine which is the correct calibration orientation?
Sounds like you have bent the calibration bar if you get different readings flipping it.
Ideally, you could take the average if the bar is in the exact reversed position.
Bruce might send you another bar or pick up some flat stock and mic it.
Thanks Thomasmyran.
The instructions for use show the calibration bar in a specific orientation so I assumed that it was normal to get different values if I flipped it over.
I've sent an email off to Bruce to ask about this issue. I'll post here his insights here in case someone else has this issue in the future.
Just a quick update:
Bruce at Arnnworx responded to my email within a few hours:
It's great to see such good support for a great product! I hope that someone else can find this info useful.
Given my experience I would highly recommend the tools from Arnnworx!
Hi Wray… yea, we fixed that just a few weeks ago. We now have a sticker on the bar to say which way is up. If you want to send it to me, we will be glad to update/calibrate yours. The bars should be straight but frankly we don’t check them unless the tool gets rejected during our set-up calibration. Anyway, we do a couple of these every week mostly due to drops but for any number of reasons. We’ll even pay shipping to return it to you…
