944 sway bar re install
Whilst installing new front struts i removed my front sway bar, but now i cant for the life of me figure out how to get both ends back in Suggestions or posts that explain this????
Early or late car? On an early car there is an aluminum mount about the size of your fist on each control arm, with a bushing in it. These hold the ends of the sway bar. On a late car there are links that go up into the control arm, with a bushing above and below.
On all cars, there are also 2 brackets that come down to support it in the middle. You should be to see how that works by looking at it.
The car has to be level, both sides in the air equally or you will be fighting the sway bar all the way. Mount the two center mounts first then slip on the end mounts and attach to the a-arms.
