Need KISS oil cooler instructions
Hi,
Had a KISS oil cooler install on my '89 951 when the motor blew awhile ago. Have installed a new motor, but now need to install a new KISS cooler.
I'm replacing the old cooler with a new unit, and have the oil lines, but the instructions on how to install have run away.
If anyone can direct me to a set of instructions so I can connect the hoses correctly, I'd be grateful.
Thanks!
Thanks!
If I recall, the line from the side of the engine goes to the bottom of the cooler. The line from the front of the engine goes to the top of the cooler.
Hopefully this will help you out. It shows you how the oil lines are routed.
http://www.lindseyracing.com/LR/Parts/TECHLROIL.html
The KISS is pretty simple. It connects in series and, I'm pretty sure, after the stock oil cooler. Both connections are on the bottom of the cooler and the cooler is not directional, either side can be the in or out.
