high oil pressure!!!
The car in question is a '88 951.
After the last oil change the oil pressure won't drop lower than 4.5bar at idle and goes up to 7 bar at wot. This is measured not going by the cluster gauge,with the engine up to temp.That rules out the sender and I also changed the oprv already with a new one.
Anyone have any ideas what might be causing this and how to fix??
