Cruising mileage
Old 07-12-2015, 10:08 PM
snb13
snb13's Avatar
Originally Posted by 944Ross
Are you running a K&N type (oiled gauze) air filter? If so you might check to see if the AFM is gummed up on the vane seals. I had that happen on a VW, the added weight of oil and the dust it collected threw things way off.
I have a bone stock car and at 70, at mile high altitudes, A/C on, with lots of big hills, I get 27. On the plains I regularly see 30+ at the same speed. Can you put the stock tune back in and see if it improves?
No K&N (I wouldn't run one of those, I believe they're a waste.) No AFM.
Can't return to stock, I'm too far down the road...
Quick Reply: Cruising mileage
