FS: Tarret sway bar billet mounts and control arm mounts
These mounts came with a Tarret sway bar set I bought from a fellow 'lister. I tried to make them work, but my racecar tub is not straight enough and there isn't enough play in the mounts to let me use them. I was able to get all the bolts in, but then the bar would bind when I torqued it up. After a few nights of fighting with it, I had to make my own mounts custom for my car.
The bar I bought is a bigger bar and the hole spacing is wider than it is on the regular bars, so you may have to drill and tap a couple new holes... but do this with the mounts already attached to the car and the bar not binding when you mark the spot for the holes.
Also for sale are a pair of control arm mounts. These work with stock and stockish control arms. The do NOT work with Charlie arms, hence why these are for sale.
Billet mounts: $250 USD
Control arm mounts: $50 USD
I will ship anywhere at the buyers expense and choice of shipper.
