Solid-State DME Relay- Beta Testers Wanted
#211
Basic Site Sponsor
Basic Site Sponsor
New Lower Sale Price
I am pleased to announce the Solid-State Relays for the 993, 964, 968, 944, 924S are now being offered at the lowest sale price ever! This lower price is a direct result of having source a German manufactured relay enclosure. However, I had to invest upfront in a huge industrial batch of these enclosures. The intention to sell a higher volume of theses relays to justify this investment. I hope for support in the Porsche community so I can continue to innovative make these and other high-quality products available to everyone.
#212
Any plans to do some 928 work? The LH computers in 928s are prone to failure and we could use a nice aftermarket source like you have done with the 944.
#213
Just ordered one as a spare, thanks!
#216
I had a URO parts relay in the 3.2 carrera. Tried to order one of these in january but it was sold out.
Ended up getting a Wittrin one, first one didn't start up. Exchanged it for another one..it worked. In June there was an instance of no start up but 2nd try was fine. I was filling up at a gas station.
Today I tried to start it up after not driving for about 10 days...nothing. It's been crazy hot here in Houston. 100+ for days now.
I had the URO one in the glove box and car started up just fine. After a short drive I swapped the Wittrin back in, no go.
Was about to order a stribel one when I thought of this SSR one. I was excited when I saw it back in stock at the right time! Hope this works. I will report back.
#217
Received mine the other day, works great!
Sajan (09-07-2019)
#218
Got mine today! Swapped it. She fired up QUICK.
Hopefully it stays that way for a loong long time.
#220
Basic Site Sponsor
Basic Site Sponsor
Diagnostics Solid-State DME Relay
I just created an optional "Diagnostics" version of the Solid-State DME relay! You can now add four LEDs that are connected to the inputs and outputs letting you know instantly if there is an issue. Here is a description of each LED:
Ignition SW – (Yellow) Input signal to power up fuel injection system and enable fuel pump control.
Fuel Inj. Power – (Red) Output indicating the fuel injection system is powered up.
Ctl. Fuel Pump – (Green) Input signal indicating the DME has commanded the fuel pump on.
Fuel Pump – (Blue) Output indicating the fuel pump is powered up.
http://www.ftech9.com/
The following 8 users liked this post by Ftech9:
75ohm (10-29-2021),
abiazis (07-07-2022),
AKCJ (11-01-2021),
AkechiMotors (10-30-2021),
DasSilberWedge (10-31-2021),
and 3 others liked this post.
#222
