Driver mirror clicking, broken motor?
Tried adjusting my drivers side mirror today and found that the mirror started click when I tried to move in any direction, almost like the gearing is stripped internally.
I checked out clark's and searched here, but I couldn't find a "how to fix the clicking mirror motor" .
Anyone out there seen this and how to fix the motor, the glass is fine, and the motor obviously gets power, so why now did this decide to crap out?
THE GEARS IN IT ARE BROKEN NEED TO REPLACE MIRROR TRANSMITION UNITE COMES COMPLETE WITH MOTOR AND RUBBER TRIM RING REMOVE MIRROR THEN REMOVE 3 BOLTS THEN UNPLUG INSTAL REVERSE ORDER NEW PART ABOUT $250.00 CAN BUY A USED ONE AT LA DISMANTLERS ABOUT $40.00
BE CARFUL WHEN REMOVING GLASS MUST SLIDE BLACK PLASIC CAM AT BOTTOM TO GET OFF. THEN REMOVE TWO WIRES FOR THE HEATED GLASS.
