Car leaning out on boost. WOT switch signal? Other causes ?
The KLR has a WOT 'switch' that is triggered when the TPS opens enough. When the switch is triggered, it tells the DME to run off its WOT maps. I think the m-tune logger displays the status of that switch, but it's very easy to test either way. The signal is one of the pins in the diagnostic port under the hood, so very easy to get to and monitor on a multimeter. If yours is not triggering, it good be the KLR (bad solder joints maybe), the TPS or the harness... Worth testing anyway.
Along with Tom's info, here's some additional tidbits to clear things up:
- there is NO WOT switch in the TPS. If you test its output and it goes up to about 4v at WOT, it's fine.
- stock 951 FPR is 2.5-bar (944S uses 3.5-bar FPR). Fuel-pressure should be about 37-38psi at idle with vacuum disconnected. Around 30psi connected
- to determine status of WOT signal from KLR to DME, connect an LED. Give it +12v on one side through a 200k resistor and connect anode to KLR WOT line (grounds when active)
Test and measure parts and confirm they are indeed bad before replacing. Or else you'll have a giant pile of spares you won't need for a decade, if ever.
Thanks guys. Clarks say to mearsure resistance across pins 22 and 23 of KLR to test TPS. I knew there was a switch and was thinking it was wot but was the idle I was thinking of. I think the KLR may not be telling dme to use wot maps. If I make up an LED as per Jac's suggestion, what wire am I am checking on ?
Will google DME inputs and see if I can find it. Might end up mounting the LED to the ones for my Vitesse knock LEDs, as would look cool to see when you hit WOT everytime
I was having voltage drop at the pump and my car would go lean / not boost - replaced the wiring and noted I had a battery with a bad cell. I kept it on a trickle charger so even though it started / seemed fine was causing some goofy issues. It was 9 years old, didn't even realize it. Just an easy thing to check that I overlooked for a long time.
Check the voltage between pins B and C -- i.e., pin by itself at the 6 o'clock position, and the pin in the 1 o'clock position. It should show 5 volts on light throttle and show ground (0 volts) when the WOT "switch" is active. It wouldn't be the first thing that comes to mind for a lean-boosting car, but it's on the list and one of the easier things to test.
Another indirect way to determining WOT map usage is to monitor the factory O2 sensor, either with LED gauge or voltmeter. When DME switches to WOT map, O2 sensor stops dithering and holds a steady voltage.
Thanks guys that info has helped a lot. Had no voltage at all at test port so we checked TPS harness and 2 wires were broken. Now have 4.9 volts at test port. Progress
Will know more in 2 days but after reading test point 9 in DME KLR test plan manual, I am left thinking that Porsche's "replace KLR" as the suggested solution, may be correct, due to the results of the tests
