Stuff to sell/give/throw away
If the fogs are cracked I will take them. I bought some acrylic lenses but haven't been able to find a set at the junkyard that doesn't fall to pieces when I try to remove them.
Any calipers to fit rear that fit this bill??
at least a 52mm single piston, 36mm twin piston, or the smallest 4 piston caliper would likely do just fine..
Trying to get my bias right and I need some bigish rears..
It's for the rear of my 924, is 924 a good enough soob story? lol
do you have a air bag control unite for a 951 1987 its orange and under the dash let me know my email is dafs586@aol.com
thank you inadvace not sure mine may be bad ithink
I'm traveling for a week (Road America) - when I return we'll pick this back up. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Unfortunately, nothing sweet coming in (although I'm looking for a new tow vehicle... and I'd like a Suburban 2500 if you know of any for sale...)
At least one is cracked...
Will a front caliper fit on the rear?
No, I don't have one of those.
I do have an ABS pump...
I'm finding out that my bias calculations were wrong because you're only supposed to calculate for one side of opposing piston calipers not both sides combined..
So anything marginally bigger than the OEM 38mm rear will work to get rear biased and up until about 53mm because it would exceed the limitation of a proportioning valve to turn them down that far..
I don't know if fronts will fit the rear but anything that fits the rear of regular 944's should fit my 924.. I think the mounting is different..
So, anything 40mm-50mm ish that will fit the rears?
https://rennlist.com/forums/924-931-...r-install.html
