1987 944 turbo air bag light
My air bag light will not turn off tried reset procedure many times what do I do next or can I disable it . Light saying air bag stays lite as well as the red center light over blinker indicator thank you for you help
There's probably an actual problem with the airbag(s). You can try something like this to remove an airbag from the system, then do the reset procedure again. Try one at a time to see which one is giving you problems.
http://www.944s2.com/how-to/how-to.htm
scroll down to the part on airbags.
I helped someone on pelican that ran into the same issue. Run your ground directly to your battery as this person did and do the airbag reset 5s on/off and it worked.
http://forums.pelicanparts.com/porsc...code-31-a.html
