No Start; Help with Diagnosis please
Car has sat up for a few months in garage.
Low on gas but I started it regularly. Added a few gallons of gas after first no start thinking it was empty.
Still will not start.
-Replaced DME Relay.
-Used Noid Light and got flickering on each cylinder while turing key
-Tach is bouncing.
-I put a fuel pressure gauge on the end of the fuel rail and am getting zero pressure with DME relay installed or jumper line while turning the key.
With Jumper Line I can hear the Fuel Pump.
Any ideas of next steps? Replace Fuel Filter? Replace 3 bar Fuel Regulator?
-Tach is bouncing.
