proper transmission cooler
Running advanced DE and open track days. Found a few old threads on trans oil coolers and need/want to see what you guys are running as coolers. Thoughts, pics, suggestions appreciated.
Thanks guys!
Dwane
Looking for a Guard LSD as well.
Thanks guys!
Dwane
Dwayne, i have seen a setup from a guy local to me. The fill and the drain plugs were removed and replaced with metric to AN adapters. A Tilton oil cooler pump is used on the drain plug side and pushes fluid through a cooler then back through the fill. The cooler is a generic bar and plate.
http://www.summitracing.com/parts/til-40-524
Someone posted a link to this company. Check out their sale stuff
http://www.batinc.net/mocal-central.htm
Dwane,
Get hold of Mathieu Savard with the Rothmans 944 in our series,he has the proper (expensive) setup with a NACA duct cooling scoop and cooler shroud.
I might have some pictures as i was thinking of doing the same ...
Cheers
Phil
Cheers
Phil
Van, how do you get airflow over the radiator in your set-up? Looks like it is flush to the floor tray.
Phil, if you have/get pics please share.
NACA ducts
Van,
What is the diameter of the inlet hose on your ducts? Did you use the same on the inlet and outlet size?
Thanks,
Don
Thanks,
Don
Start by measuring the temperature of your fluid after a session to determine whether you have a cooling issue. No sense in adding a cooler unnecessarily, unless you're looking for quality time in the garage. There is a school of thought that says the cooler is an unnecessary point of failure that can dump fluid when it breaks and make you all kinds of new friends.
