My 924 stalls going over uneven road
Do you know of a way to test & see if that is the issue prior to replacing it? I'm just curious because I'm not sure how difficult it is to locate one of those.
Item should be easy to find and cheap to buy...not rocket science stuff.
Be sure to check the connector to it, the metal connector clips can be corroded or enlarged from old age and being handled....so properly check all connectors that are related to the ignition system first.
It might be that you just have some loose pins. But if you are in a hurry you can post and add on 924board.org looking for this item.
I would listen to Dan(ideola) here and on 924board, he has several 924s, he has been into the 924 scene for a long time and he is very organized as you can probably tell.
I would also check and replace the ignition coil...it might have a defect that is triggered by bumps or vibration.
All the valules of the ignition system are available in factory manuals, or even Haynes manuals for your specific vehicle, take care that US models are different from the rest of the world cars and there are several 924 variations based on years of production, markets and ofcourse factory model designation.
