rear toe/camber change
What's the relationship between camber and toe on the rear? Is it the opposite of the front - i.e. moving towards positive camber in the rear results in more toe out, negative camber causes toe in? I'm guessing that's it, because the camber adjustment is in front of a fixed point (the axle). So when the trailing arm moves up in an arc towards negative camber, it pulls the wheel closer to the center of the car, but it pulls from a point in front of the axle, causing toe in. Does that sound correct?
I have been checking my toe settings with strings, and what I'm seeing is that my RL has less negative camber than the RR, but it also has a little toe out. So I wonder if this is a case of the camber in the rear drifting somehow, or if both settings have gone out of whack independently. I've had the camber drift towards positive on the FL due to driving on the track.
Cheers,
Mike
