Noisy heater fan
My heater fan motor is whinning.....is the little hole in front of the heater motor cover (engine compartment) used for oiling the motor (duh).....?? I know this may seem obvious.....but I guess I could be oblivious.......good one eh?
I have a spare blower assembly in my garage I checked, and there's no oil hole for the motor. I doubt lack of oil would cause a whine, although I might be wrong. It's more likely to be a leaf caught against the blades or something.
Did it start doing it all at once?
No, its been going for a while....sounds like worn bearing...not a blade scrape.....on mine there is a little hole with a rubber cap that looks like an oiling hole.....you don't have this?....mine is a 79 924 na
The early 924's, 944's and 924S's share much of the same heater components.
Give the hole a dose of 3 in 1 and see what happens. Can't hurt.
Still might have to take the motor out and replace the bearings. Porsche used open cage bearings until the 85.5 and later models. The open cage bearing in the front of the cooling fans will cause the armature to sieze up.
