2.5L Euro Piston serch
Lifetime Member
Lifetime Member
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
TaboII
Thought I would give this another shot and see is any of the Euro Rennlisters can lend me a hand. I am looking for a reasonably priced set of 2.5L N/A pistons in good shape that I can install into a US model car. Anyone out there on the Euro side of the plaint able to help out?
Thanks In advance
TaboII
Thanks In advance
TaboII
I have a set of '88 high-compression 2.5 8-valve pistons, which I believe are the same as the Euros used all along. They're stock pistons, with about 130K on them. They look decent, but let me measure them and make sure they're OK.
Bonus: I'm in MA so you can pick them up and verify they're in good condition.
I also have the rest of my '88 M44/09 engine to pick over - the block is toast though. But everything else is good.
Let me measure the pistons and make sure they're in spec.
Bryan
Bryan
Lifetime Member
Lifetime Member
Brian Just let me know PM Me and I will shoot you my cell phone number. I am lookign for a real resonable price as I am expecting a new member of the family soon. thanks.
P.S. I believe your right about the 88 speck on the pistion VS the euro. I will check tonight.
TaboII
TaboII
The pre 88 pistons are rated at 9.7 to 1 compression. The 88 pistons are rated at 10.2 and the euro pistons are rated at 10.5. According to the factory manuals there is a diiference between the Euro pistons and the 88 pistons.
The same compression ratio can be had though by installing the 88 pistons and then having the head milled. This is what I did and it was much cheaper as I was able to get a new set of pistons and rings off of e-bay for less than $350.00.
