the 951 see-saw
Old 09-04-2003 | 12:45 AM
car_slave's Avatar
car_slave
I'm using stock 15" pd's. Guess I could cut them down. The kla's have five inches of shock travel, of which only about four are used. Let think of a good price for you on the Koni's.
Old 09-04-2003 | 06:38 AM
tifosiman's Avatar
tifosiman
Originally posted by car_slave
I just put the KLA rear coil-overs on my lowered car. Well they come with ten inch springs which puts the adjusters up a little too high into the wheel wells, so at some point I want to buy some eight inch 200lb springs to better match the 250lbs welts up front with stock torsion bars (not sure what they are, the car came with 26.8 mm front, and 18mm rear sways, plus 951 A-arms) although the car drives fine as is for now (hardly driven it yet). So I am now selling a brand new set of Koni yellow rears if anyone is interested, I bought them to fix my bouncing rear end and then came to the conclusion that the torsion bars were getting old. They only have one thousand miles them.
I really don't understand what you are saying, what is wrong with the adjusters being higher up? Wouldn't they rub the wheels if they are lower?
So, mine are arriving today, I may install them tonite if I can't stand to wait until saturday. Did you see any change in ride height at all?
Tifo
Old 09-04-2003 | 09:47 AM
tifosiman's Avatar
tifosiman
oops. I just thought about my statement and realized that the springs are on the other side of the wheel well, so they can't hit. duh!
Tifo
Old 09-04-2003 | 06:41 PM
car_slave's Avatar
car_slave
tifo, when you mount them you will see the UPPER clearance problem with the lock rings, it can work, but for easier access having the ring a little lower would help. P.S. I like what what you did with your car.
Old 09-04-2003 | 07:02 PM
car_slave's Avatar
car_slave
BTW, I'm looking for around $145 (or trade) on the barly used koni sport rears
Old 09-04-2003 | 08:04 PM
Super Dave's Avatar
Super Dave
one more thing about the coilovers. let me make sure I understand. Do they mount with the adjustment ring/nut for the springs towards the top? If so is that so that you have clearance with the spring and the body? And if you had 8" springs then the adj. ring/nut would be lower and have even more clearance, right?
Old 09-04-2003 | 08:32 PM
tifosiman's Avatar
tifosiman
Dave,
You are correct. I just instsalled mine. There would not be enough clearance with the spring on top. I'm going to post a quick initial review in a separate thread.
Tifo
Quick Reply: the 951 see-saw
