Scratched Inner Hub
Yep. An expensive mistake, especially on 88/89 model when i scratched one of mine. Now i pull the hub and run it by the shop to pull ans seat the bearings for a few bucks.
Not sure how it happened as I used a brass punch. Guess I need to clean the axle off and take a good look. I think I can get one inexpensively. There's a parts yard near by with two early models.
Tiger, the scratches were either there before I removed the races or happened upon removal. I have a bearing/seal driver kit, but I don't see how it helps for removal. Maybe it'd work for the smaller outer race.
There's a technique I use - with the MIG welder, put a bead on the bearing race. As the weld cools, it will contract and shrink the bearing race so it drops out.
I'll make a video doing it the next time I get a chance.
