thermostat install
thermostat install
guys...need a bit of help on a thermostat installation..should the t-stat be loose or tight in the water pump neck? Mine is loose..should I get shims to tighten it up? jus wondering..new pump and a P-car newbie to boot.
please look at the PET 6 or a service manual - if you use the brass thermostat, there is a special seal that has a grove in it that goes around the brass to insulate the brass from the aluminum and prevent galvantic corrosion. STANT sells a stainless steel thermostat and recommends an O-ring instead of the special seal - that will work also. With the seal in place there should be no play in the thermostat. Note that if you use the Stant thermostat with the O-ring, the O-ring goes behind the thermostat.
