stripped cam tower bolt
Old 08-23-2003, 11:03 PM
944J
944J's Avatar
Angry stripped cam tower bolt
The head is stripped where I want to bolt the cam tower down.
I have all the other bolts in and this one is stripped and had been leaking oil before.
What is the best way to fix this?
Is there a way to do it without taking everything off again?
Helicoil? Tap it bigger? Fill with jbweld then tap?
Thanks in advance...
Old 08-23-2003, 11:37 PM
Martin
Lifetime Member
Martin's Avatar
one of mine did that, i filled the hole with loctight and installed a longer bolt, there are a few extra turns that the standard bolt doesn't reach, do not torque it fully.
Old 08-24-2003, 03:19 PM
944J
944J's Avatar
how long of a bolt did you use? and what did you value did you torque it to? did you use loctite red, green, blue? and how has it held up?
thanks!
Old 08-24-2003, 06:31 PM
944J
944J's Avatar
I just went to NAPA and got the next size longer bolt, maybe 1cm longer.
I put it in and it tightened right up. Then took it out and added locktite blue and torqued down to around 14lbs.
Thanks for the tip!
Quick Reply: stripped cam tower bolt
