Starter not catching the teeth
Well, I put a turbo aluminum flywheel, turbo pressure plate and turbo disk into my 924S, and the starter wont engage the ring teeth. I have tried two different starters (both tested good). The clutch housing AND the starter for the turbo's and NA's are the same part numbers. So, anyone want to venture a guess as to what I might be missing?????
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
That is the strange thing, it makes a sound like it is just nicking the outside of the teeth when it kicks out - but the turbo ring, if anything, is slightly larger in diameter than the na.
