Cap and Rotor
Cap and Rotor
How easy is it to do? I just ordered the parts from pelican... should be here tomorow, anyone have a write up or is it just so easy and dummy proof?
It's very simple to do. A stubby screwdriver helps to access the bottom "screwlock". I have heard of rotors coming off the shaft, but if you tighten it down well you shouldn't have this problem.
1.Get a stubby phillips screwdriver
2.At the top and bottom of the dist cap there is a recessed screw turn it 90 degrees (or untill it disengages) The cap will then come off.
3.Replace wires one at a time so as not to disrupt timing.
4--2
3--1
4.use allen head to get rotor off of cam shaft thingy
5.replace with new rotor (Make it tight!!)
put new dist cap on.
DRIVE
Christian
4--2
3--1
DRIVE
Christian
yup - this is only if you forget the orientation of the rotor... don't do that - just put the new rotor back on right away. This pic is for folks that forget or are doing major engine work or belts.
Do you really need to use loctite on the bolt that holds the rotor in place?
I make sure to replace this bolt every time, so I can tighten it pretty well when I put it in. I also use anti-sieze compound on it. I never had one come off on me, in 11 years of owning my car.
I know what happens when the rotor spins freely, but I never really heard of one of the bolt coming loose.
-Kevin
-Kevin
Originally posted by Jonas Goldsmith
loc tite? bolt coming loose? what if i just tighten it down good and tight?
Be careful on how tight you go with it... I nearly snapped the head off of mine tightening it. I have an allen head bolt instead, harder to over-torque it.
-Kevin
I agree Skip, if the blue loctite prevents someone from being tempted to over-torque the bolt, then it should be used.
I guess using the red loctite would be only if you were sure that rotor would last the life of the car.
