New and Remanufactured injectors available
Developer
Flow-Matched Fuel Injectors For The Porsche® 944/S2/951 and 968
Description: We now have both NEW and RE MANUFACTURED electronic injectors for your 944 though 968 series Porsche®. All injectors come with new O-rings in the proper size for the Porsche® intake manifold.
New Injectors: We feature new LUCAS injectors made in the USA to replace your OEM Bosch injectors that are no longer available. The Lucas brand has been and still is the fuel injector of choice for Ford, Chevrolet, Porsche®, BMW, and Mercedes-Benz. Our new Lucas will match exact factory's original air/fuel mixtures, and the Lucas injector is not prone to over-heated injector coil failure and warm leak-down hard hot-starts like the Bosch injector was. 36 Months/Unlimited Miles Warranty
Re manufactured Injectors: If you still want the OEM Bosch injector for your 944, 944S2, 951 or 968 (after reading the benefits of the Lucas injector above), then we can get you a set of them re manufactured. Our reman process starts with good, quality U.S. injector cores, no imported or junkyard-grade injector cores are allowed. The old o-rings and rubber seals are removed and discarded, along with the old filters, pintle caps and o-ring retainers. All are back-flushed and ultrasonically cleaned. Each injector is tested for dynamic and static flow rates at three different fuel pressures. Each injector is also tested to make certain the solenoid resistance is strong and within mfg. specs. Lastly, all get a drop of lube along with new Viton rubber parts, caps and filters. 12 Months/Unlimited Miles Warranty
Priced and sold in matched sets of 4 injectors.
http://928motorsports.com/parts/flow..._injectors.php
