87 944S A/C Acting funny - Seeking advice
Hello everyone!
Guess it's about time for something else to break! Today for the second time my A/C refused to engage when the switch (snowflake) was pressed. Trying it repeatedly over a period of several minutes, the compressor finally kicked in.
Anybody else had this happen? A/C blows some cool air when on, but not really cold. May be time for another can of 134A!
Here's what I'm thinking.
Switch has a problem, corrosion, age, whatever.
A/C freon could be down a bit?
or
Maybe the A/C relay is failing?
Anybody care to tell me if I'm way off base on this? Is there a way to test the relay - or does it really matter when starting the compressor? Anything else I should be looking for.
Shucks..... it's been doing so good for soooo long now.
Some advice would be really appreciated about now.
Marshall McCray
1987 944S - Just a little too hot of a car, to suit me at the moment.
or
Marshall McCray
Time for more 134a! The compressors have a "low pressure" switch that will prevent them from running if the refrigerant is low.
Be careful not to overcharge the system!
