Wastegate help?
Would a aftermarket wastegate hold the boost better then the stock wastegate? (would it hold it to red line) Or is it the same thing. All you people that have a upgraded wastegate did you have a performance increase or not.
Thank you
Thank you
Yes most definitely a peformance increase from holding boost to redline with a flat curve. I've got a new upgraded stock 39mm wastegate with a stiffer spring that holds whatever boost you want to redline.
