FS: 951 5P trans w/lsd
5P ('86 turbo open diff trans w/ cooler) with 951 lsd equipped. Diff locks up great. The trans cooler bore on the pump side weeps a little, I was going to tap it for npt and run a different cooler but came up on another trans and am going to run the newer one. I tried a new o ring (including different sizes), new clip, sealant... It still wept a small amount so I think the bore is a little wallowed out. I have an extra diff cover from an NA without the provision for the pump that I could throw in, you'd just have to plug the rear hole for the cooler line. I also have a good oem trans cooler loop that I can include. Other than that, the trans is in great shape.... shifts good. Shift linkage is in good shape. Priced good due to the leak. $800 obo plus shipping (from 76522). Interested in trades... Looking for a 30+mm front sway, 1.875" ID 400-450lb 8" springs, rare and unique parts, etc
Video coming soon
Video coming soon
Bump...Will also trade for an ac/dc TIG setup...
I talked with Ian from 944online.com and he has good pump face with a good bore for $100... an easy option for the buyer to have a perfect trans. Gaskets are NLA so one would need to be made but that's super easy.
