What should I use antiseize on for headgasket reassembly?
I'm guessing all of the exhaust bolts (I already used it on the exh. manifold studs) and the spark plugs. Should I use it in the waterpipe bolts, head studs/nuts, cam carrier bolts, etc.? Thanks...
a drop of oil on the rest yeah, but I cant see any reason not to use "coppaslip" or similar on parts which will be a pain to remove later if needed.
again a "little" ammount
