Vacuum Line Routing and Replacment
So the vacuum lines (hard lines) on my 1985 944 NA are basically a mess. There are some places where the lines were cut and melted to seal them, some where they are missing and just overall need a full once over re-run. I found the diagram on clark's garage but it isn't the clearest or most details. I can probably do it based off that but was hoping someone may have a little better link or picture of the routing details. Also where can I get the hard plastic line that is used on these cars? Can't seem to locate a supplier and trying to avoid the dealer.
You can get it from the dealer by the meter. It's cheap. N.020.139.11. Or from Wurth. 4 mm OD x 2 mm ID. Last time I bought it, $2.20 list price per meter.
Kevin
Catellus Engineering
Kevin
