Anyone with a stripped 944 race car?
#47
At least im not a ricer trying to make a dinky early n/a look like a carrera GT....
(am talking to Dan on AIM right now...we dont actually hate eachother...that much... )
#53
Originally posted by Dan Gallagher
so if i go under the car and scrape off coating how much will it weigh? hell this car is old i bet there is 100lbs of road tar stuck under it.... but that sounds like the kind of job that will **** off everyone in the shop for days
also i have an optima battery but i havent put it in yet, still a regular battery in there right now
Here is a NASAforum thread on this.
944-Spec Thread on Weight Removal
#54
Here are the links that work (I finally fooled the system to make them show up correctly!!):
http://www.huntleyracing.com/rollcages/newzebra_rollcage1.jpg
http://www.huntleyracing.com/rollcages/newzebra_rollcage2.jpg
http://www.huntleyracing.com/project_cars/chassis1.jpg
http://www.archcartpro.com/users/dkhajavi/images/p8040001.jpg
http://www.archcartpro.com/users/dkhajavi/images/p8040002.jpg
http://www.archcartpro.com/users/dkhajavi/images/p8040003.jpg
http://www.archcartpro.com/users/dkhajavi/images/p8040004.jpg
http://www.archcartpro.com/users/dkhajavi/images/p8040006.jpg
http://www.archcartpro.com/users/dkhajavi/images/p8040007.jpg
#57
it doesnt look like much in the pictures but visualize what it will be in a month or so.
still scraping crap off the floors:
shaved mirrors and door handles :
gotta clean up the wires after i clean and paint the floor... notice the dash
#58
cleaning the floor is taking forever, on the plus side we have a couch right by the lifts and after about an hour in the car the adhesive remover gives me a nice little high so i can go sit down and zone out
#59
There isn't very much true undercoating inside the car. I think what you might be referring to removing is the sound deadening material. It consists of what seems to be fibrous asphalt panels (approx 3/32" thick) that are bonded to the inside of the tub. I used a propane torch to gently heat these things and they lifted right out with a putty knife / scraper. I removed all of this stuff in approximately 1.5 hours using this method. Works much better than frying brain cells with that nasty adhesive remover stuff . . .
Regarding the actual undercoating (that covers the entire underside of the tub and also a little inside the tub), I used a 13,000 rpm angle grinder with a very stiff wire brush cup attachment on it. Takes the stuff off very quickly but leaves a HUGE mess. Make sure to wear a very good filtration mask over your nose and mouth when doing any form of grinding or sanding that creates dust in the air.
Jeff
Jeff
#60
yea the sound deadening is what im doing right now, if nothing else just for a cleaner surface to paint over.... like i said earlier i think if i started trying to remove the undercoating it would be messy and i would start making enemies at the shop
