Power steering pump
Does anybody have a picture of the power steering pump on the car. I think that I put mine back together wrong and can't figure out how to get it back on the car.
That is awsome. Your a life saver!!! I knew that membership would pay for itself quickly.
You wouldn't happen to be able to tell me how it attaches to the car would you? I kind of remember but it just doesn't look right when I put it up there.
The pump mounts using a long mounting bolt secured through the bracket on the engine and is tensioned with the adjustable connecting rod. It's removed by removing the mounting bolt/nut and swiveling the pump up in order to remove the spacer from below. Installation would be the reverse. The manual says use loctite 270 on pulley bolts, if they were removed.
