wiring question >pic<
I'm installing my porsche cd-1 player back in my car and the foam? thing attached to the wires has deteriorated.
What should I use to remove the foam stuff and where can I find a replacement? Do I even need it? Should I use crazy glue to attach the new foam thing? Thanks in advance!!
The foam is only to remove the rattle noise that occure when the whole car shakes (from the motor running). Just put a piece of foam around it.
btw. the unit is a Noise filter. It filters high frequency spikes out form the power supply to the CD. Otherwise there could be som noise from the Ingnition going into the radio/CD.
