Just changed the transaxle fluid to Redline MT90
Noticed an immediate difference in the 1-2 and 3-2 shifts - no longer "notchy" and much smoother engagement. Yeah, I made sure I could get the top fill plug out first!
Easy to access to get the plugs out - I used some degreaser and my 1200 psi power washer on it yesterday to get rid of the caked grease and crud around those plugs. Picked up a great 17mm long hex 1/2" drive socket for $10 from the local auto tool supply - can't imagine trying to get those out with a 6" allen key either.
In anycase, an easy re & re - using my Mity Vac pump (no A-P jokes Sandor
). Used my magnetic pick up to fish around inside the transaxle case when nothing showed up in the drained fluid. There were some very fine shavings - all steel, and nothing in brass I could find in the case. At least no gear teeth!
I don't know what was in there before, but it was brownish-red, not clear at all like most heavy gear oil, but clean and no "burned" smell!
Thanks to Skip for the advice!
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Hey Randy,
I made the same call about 3 weeks ago after talking to Redline. How much fluid were you able to get in there? I got a hair over 2 bottles and then recently read that it holds about 2 and 2/3's.
Kevin
Kevin
Originally posted by Tom Carson
...guess Randy is tooling around and can't be disturbed right now
Back to Kevin M's question - I got 2.5 bottles of that Redline MT90 into the transaxle. I let it drain completely for about 1 hour, as I wanted to replace the dino fluid that was in there.
Shifting is so much better - smoother action hot or cold and not "notchy" anymore!
