Vacuum hose kit supplier.. Anyone try these guys?
Administrator - "Tyson"
OE, 1.70 per foot. After using the silicon, I much prefer this stuff.
http://techtonicstuning.com/main/ind...oducts_id=1720
My local import shop only uses similar hose (except his is made by Wurth).
What's the total cost to replace all the vacuum lines on an '86 951, including parts and labor, if I went to a specialty Porsche shop?
Is there an all encompassing parts kit for all the vacuum lines?
Thanks!
Thanks!
Or you can do it yourself on the cheap.
Lindsey racing has a "end all" kit, with venturi delete hoses. Labor? Well, they'd have to pull the intake, clean the gasket surfaces, gut the hoses out. Remove the factory fitting for the AOS into the j-boot to reuse. And that's about it. Oh, and hopefully they don't break the cycling valve... that's a pricey piece of crap right there.
http://www.944online.com/cgi-bin/ASI...ystem-944turbo
Anyone have a link to the Lindsey racing one?
What specific tools do you need to do all of the labor yourself? How many hours should I expect to invest if it's my first time?
Thanks!!!
Well, LR doesn't sell a kit like that one. Theirs is a "master kit." The kit there is pretty inclusive and I'm not against you getting it. If you want to replace the KLR hose, you can. I'm not sure that it often ruptures but better safe than sorry. My original one is still on my car. I'm not sure how their aluminum-looking sealing washers do at leaking leaks. I put copper ones on all of my banjo fittings.
Tools:
5mm allen keys.
6mm allen keys. (You need to be able to use one to torque the intake with later on)
Scraper that takes razor blades.
Plastic "razor blades" (You can get them in packs of 20 at autozone)
Offset 13mm wrench (12-point preferred).
10mm wrench.
12mm wrench (Banjo bolt on intake)
13mm open end wrenches (cruise control cable).
Torque wrench. (spec for intake manifold is 15/16ft-lbsf).
Whatever nut-driver you need for your hose clamps (1/4" and/or 5/16").
Penetrate oil (kroil is good... you need it to help with the intake gaskets.)
Picks (For TPS connector clip)
Papertowels (to stuff in intake ports to keep out debris.
New hose clamps... advance auto has a assorted set where the smallest size works well for vacuum lines. Don't know the size or I'd just order a **** load of them. You'll need some new clamps (about 3/8") for the other hoses too.
Also, you'll NEED a set of these. I'd go to SEARS and pick up a set. They're awesome at cutting through the factory hose clamps.
If you remove your fuel lines for the fuel rail you'll need a 17mm and 19mm wrench. If your fuel lines are original you'll risk cracking them if you remove the rail and intake as an assembly and pivot it out of the way. It would be wise to disconnect them and leave the rail attached to the intake.
Hours? Most of your time will be cleaning the intake surfaces without scratching the finish... and figuring out where you want your hose clamps. So, about 4hrs... so buy a six pack.
Tools:
5mm allen keys.
10mm wrench.
