Early offset rear spacer removal
So I was trying to adjust my parking brake and found that there was no access hole after taking off my wheel. I think that the OE spacer found on early cars is covering the access hold in the hub and rotor, but wanted to make sure I had a correct understanding of how everything is assembled. I think it is:
hub->rotor->spacer->wheel
If this is correct, then the spacer is either mechanically attached to the rotor in some way or is rusted on pretty well. Should I just take a mallet to it to take it off?
