Need help!! Wire locations PICS.
Since this car has been disassembled for almost a year and half I kinda forgot where these wires went. One of the long wires is connected directly to the positive battery terminal but do not have a clue where this thing goes. I was thinking the starter?? Below is a picture of the postive battery terminal cable I'm talking about.
Another set of wires I cannot figure out for the life of me are these 2 brown wires that come out of the main wiring harness. These 2 wires look pretty much the same but there inner diameter hole are different sizes. Below is a picture.
Last but not least are these 2 sets of wires with 2 wires each. I'm assuming one is positive and the other is negative on both sets? Alternator wires? AC compressor?
Thanks for the help guys once I figure out where these wires are GO, I can crank my new engine over!! Also what oil do you recommend I run for a break in?
THANKS!
THANKS!
The large red wire from the battery should go to the starter.
The brown wires are grounds. I think, based on their location, that they go on the bell housing studs.
The wires with the rubber plug go to the alternator.
I'm sorry, I don't know where the other wires go, but they could be the A/C compressor power.
Hope this helps.
Hope this helps.
