Anyone have an '89 951 Wiring diagram for an aftermarket CD Player?
Hi, I purchased a 180 watt Aiwa CD player from Frys and installed it the other day. The next day I came to take the car out, it failed to turn on.
Turns out the battery decharged. I thought It was just an old battery, turns out it was the CD player's wiring, that left a hotwire standing, and decharged my battery overnight. Do any of you guys have a diagram of the '89 951 wiring that I can use to install the CD player correctley?
Thanks.
-Cyrus
Thanks.
-Cyrus
right click save as, and open it up w/ something you can zoom in w/. I made sure that it was possible to see by zooming in. I tried to make it a reasonable size w/out sacraficing the text.
Okay, thanks. I tried right clicking on my Win98 Comp, and the "Save as" option is faded out. Lettme try it on my other comp with XP to see if it works.
Thanks for your time.
I just installed my alpine over the weekend. The speaker wires are self explanatory or you can use a AA batter to test. For power, the fat green wire goes to the radio's red wire....this is your ignition on wire. The yellow wire on the CD player goes to the red wire on the car...this is your constant on power. Hope that helps. Make sure you hook up the black antenna power wire to the radio's red wire also...it needs power in order to get reception.
